Issues with Ethernet connection
I have just received the KC868-M16-V2.1 board with PoE module.
I am able to power the board ok with PoE. however I am unable to get ESPHome to connect via Ethernet.
ESPHome config is
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
I have also added static IP as follows:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
    static_ip: 192.168.85.24
    gateway: 192.168.85.1
    subnet: 255.255.255.0
    dns1: 192.168.85.1
Getting errors about IP when using DHCP
[16:51:12][I][ethernet:248]: Starting ethernet connection
[16:51:12][W][component:157]: Component ethernet set Warning flag: waiting for IP configuration
When using StaticIP it looks promising
[16:51:12][I][ethernet:259]: Connected via Ethernet!
[16:51:12][C][ethernet:515]:   IP Address: 192.168.85.24
[16:51:12][C][ethernet:516]:   Hostname: 'energy-monitor'
[16:51:12][C][ethernet:517]:   Subnet: 255.255.255.0
[16:51:12][C][ethernet:518]:   Gateway: 192.168.85.1
[16:51:12][C][ethernet:523]:   DNS1: 192.168.85.1
[16:51:12][C][ethernet:524]:   DNS2: 0.0.0.0
[16:51:12][C][ethernet:536]:   MAC Address: E4:65:B8:6A:91:FC
[16:51:12][C][ethernet:537]:   Is Full Duplex: YES
[16:51:12][C][ethernet:538]:   Link Speed: 100
However it is unable to be seen on the network at all.
I have tried different cables and ports on my network switch.
you can try to test this yaml file. after downloaded firmware, re power on of board.
esp32:
  board: esp32dev
  framework:
    type: arduino
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-zmpt101b
    refresh: 1min
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_1).state);
  - platform: zmpt101b
    name: "m16--AI zmpt 34"
    adc_pin: 34
    unit_of_measurement: V
    accuracy_decimals: 1
    state_class: "measurement"
    name: "m16--AI zmpt 36"
    adc_pin: 36
    name: "m16--AI zmpt 39"
    adc_pin: 39
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    update_interval: never
    attenuation: 11db
  # - platform: adc
  #   name: "m16--AI-1"
  #   pin: 36
  #   id: adc36
  #   update_interval: 60s
  #   attenuation: 11db
  # - platform: adc
  #   pin: 34
  #   name: "m16--AI-2"
  #   id: adc34
  #   attenuation: 11db
  # - platform: adc
  #   pin: 39
  #   name: "m16--AI-3"
  #   id: adc39
  #   attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    number: 1
    sensor: adc35
    number: 2
    sensor: adc35
    number: 3
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    name: "Measured Current-1"
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
  - platform: template
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    name: "Measured Current-2"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    name: "Measured Current-3"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    name: "Measured Current-4"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    name: "Measured Current-5"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    name: "Measured Current-6"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    name: "Measured Current-7"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    name: "Measured Current-8"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    name: "Measured Current-9"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    name: "Measured Current-10"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    name: "Measured Current-11"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    name: "Measured Current-12"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    name: "Measured Current-13"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    name: "Measured Current-14"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    name: "Measured Current-15"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    name: "Measured Current-16"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
Uploaded the code you supplied, output is attached but I filtered the results and can see the same ethernet failures
Compiling .pioenvs/m16/src/esphome/components/ethernet/esp_eth_phy_jl1101.c.o
Compiling .pioenvs/m16/src/esphome/components/ethernet/ethernet_component.cpp.o
[10:25:36][I][ethernet:248]: Starting ethernet connection
[10:25:36][W][component:157]: Component ethernet set Warning flag: waiting for IP configuration
[10:25:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:26:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:26:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:26:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:26:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:27:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:27:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:27:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:27:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:28:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:28:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:28:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:28:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:29:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:29:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:29:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:29:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:30:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:30:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:30:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:30:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:31:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:31:21][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:31:36][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:31:51][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
[10:32:06][W][ethernet:265]: Connecting via ethernet failed! Re-connecting...
A full reboot of the unit sees the same errors in the logs.
.zip   m16output.txt.zip (Size: 23.3 KB / Downloads: 507)
do you have re power on of board?
Sorry what is "re power"
I rebooted the board yes.
I will test now removing the PoE board and use the power adapter to power the board.
Yes same errors with the PoE board removed and using the power brick that came with the unit. After flashing I got the error, powered the unit off and reconnected after 20 seconds and the same error about unable to get IP.
If I put that ethernet cable into my computer it connects to the ethernet and gets an IP ok.
re power on = power off board -> power on board.
Yes I did this and same result.
if really can't work, add whatsapp number: +86-15381188302 tell us your order number, where you buy from. when you bought.
2 Guest(s)
