KC868-A2v3 ESPHome yaml for home assistant
  friendly_name: a2v3
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 48
     scl: 47
     frequency: 400kHz
uart:
  - id: uart_1
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 7
    rx_pin: 15
  - id: uart_sim7600
    baud_rate: 115200
    debug:
      direction: BOTH
      after:
        timeout: 10ms
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
    tx_pin: 10
    rx_pin: 9
    pin: 40
    pin: 39
  - platform: uart
    uart_id: uart_1
  - platform: uart
    uart_id: uart_sim7600
    data: "AT+CGSN\r\n" # read 4G SIM7600 ID
      number: 16
      number: 17
      number: 18
      number: 8
      number: 4
      mode:
        input: true
        pullup: true
      number: 5
      mode:
        input: true
        pullup: true
      number: 6
      mode:
        input: true
        pullup: true
      number: 38
      mode:
        input: true
        pullup: true
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "A2v3");
esphome yaml file download:
.txt   A2v3-HA.txt (Size: 2.39 KB / Downloads: 399)
hello, is this valid for A2V4 as well?
thanks
we don't have A2v4 board. take a photo of your PCB.
