[arduino code examples for A8v3]-02 Read digital input ports state
* Description:
* This Arduino program reads the state of a 16-channel PCF8575 I/O expander
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
PCF8575 pcf8575_IN1(0x22); // The I2C address of the PCF8575
    pcf8575_IN1.begin(); // Initialize the PCF8575
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 8; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 731)
.zip   2-digital-input.ino.merged.zip (Size: 189.5 KB / Downloads: 642)
