04-20-2025, 06:34 AM
* Description:
* This Arduino program reads analog values from four analog input pins (A1, A2)
* and prints the values to the Serial Monitor. The analog inputs are defined with specific
* GPIO pins and the program reads the voltage levels from these pins every 2 seconds.
* Pin Definitions:
* - A1: GPIO 7
* - A2: GPIO 6
#define ANALOG_A1 7 // Define GPIO pin for analog input A1
#define ANALOG_A2 6 // Define GPIO pin for analog input A2
void setup()
Serial.begin(115200); // Initialize serial communication at 115200 baud rate
delay(500); // Short delay to allow serial communication to start
pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1
pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2
void loop()
// Read and print analog values from the defined pins
Serial.print("A1=");
Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1
Serial.print("A2=");
Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2
delay(2000); // Wait for 2 seconds before the next reading
3-analog-input.zip (Size: 698 bytes / Downloads: 369)
3-analog-input.ino.merged.zip (Size: 184.59 KB / Downloads: 364)
