04-20-2025, 07:00 AM
* This program controls a 8-channel relay board via a PCF8575 I/O expander.
* It sequentially turns on each relay and then turns them off in a loop.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
* - 200 milliseconds between switching relays
#include <Wire.h> // Include the Wire library for I2C communication
#include <PCF8575.h> // Include the PCF8575 library to control the I/O expander
#define SDA 8 // Define the SDA pin
#define SCL 18 // Define the SCL pin
#define DELAY_TIME 200 // Define the delay time in milliseconds
// Set I2C address of the PCF8575 module
#define I2C_ADDRESS 0x24 // I2C address of the PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS); // Create a PCF8575 object with the specified I2C address
Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)
// Initialize serial communication for debugging (optional)
Serial.println("PCF8575 Relay Control: Starting...");
// Initialize the PCF8575 module
pcf8575_R1.begin();
// Turn off all relays initially (set all pins HIGH)
pcf8575_R1.write(i, HIGH); // Set all relays to OFF (assuming HIGH means OFF for relays)
// Sequentially turn on each relay
pcf8575_R1.write(i, LOW); // Turn on the relay at pin i (LOW means ON for the relay)
delay(DELAY_TIME); // Wait for DELAY_TIME milliseconds
// Sequentially turn off each relay
pcf8575_R1.write(i, HIGH); // Turn off the relay at pin i (HIGH means OFF for the relay)
1-relay.zip (Size: 924 bytes / Downloads: 426)
1-relay.ino.merged.zip (Size: 189.21 KB / Downloads: 443)
