04-20-2025, 07:44 AM
* This Arduino program reads 64 input channels from 4 PCF8575 modules on I2C Bus-2
* and controls 64 output channels on 4 PCF8575 modules on I2C Bus-1.
* When an input pin is pulled LOW (connected to GND), the corresponding output relay is turned ON (LOW).
* Otherwise, the relay is turned OFF (HIGH).
* I2C Bus-1 (Outputs):
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output1~16 : 0x25
* - Output17~32 : 0x24
* - Output33~48 : 0x21
* - Output49~64 : 0x20
* I2C Bus-2 (Inputs):
* - SDA: GPIO 12
* - SCL: GPIO 11
* - Input1~16 : 0x25
* - Input17~32 : 0x24
* - Input33~48 : 0x21
* - Input49~64 : 0x20
#include <Wire.h>
#include <PCF8575.h>
// === Create two independent Wire objects ===
TwoWire I2C_Output = TwoWire(0); // I2C Bus 1 - for output control
TwoWire I2C_Input = TwoWire(1); // I2C Bus 2 - for reading inputs
// === Output PCF8575 modules (connected to relays) ===
PCF8575 output_1(0x25, &I2C_Output); // Output 1-16
PCF8575 output_2(0x24, &I2C_Output); // Output 17-32
PCF8575 output_3(0x21, &I2C_Output); // Output 33-48
PCF8575 output_4(0x20, &I2C_Output); // Output 49-64
// === Input PCF8575 modules ===
PCF8575 input_1(0x25, &I2C_Input); // Input 1-16
PCF8575 input_2(0x24, &I2C_Input); // Input 17-32
PCF8575 input_3(0x21, &I2C_Input); // Input 33-48
PCF8575 input_4(0x20, &I2C_Input); // Input 49-64
// === Arrays to manage all input/output modules ===
PCF8575* inputArray[4] = { &input_1, &input_2, &input_3, &input_4 };
PCF8575* outputArray[4] = { &output_1, &output_2, &output_3, &output_4 };
Serial.println("KinCony 64-Channel Input-Output Mapping Test");
// Initialize I2C buses
I2C_Output.begin(48, 47); // SDA: GPIO48, SCL: GPIO47
I2C_Input.begin(12, 11); // SDA: GPIO12, SCL: GPIO11
// Initialize all PCF8575 modules
for (int i = 0; i < 4; i++) {
inputArray[i]->begin();
outputArray[i]->begin();
// Initially turn off all relays (set to HIGH)
for (int j = 0; j < 16; j++) {
outputArray[i]->write(j, HIGH);
for (int chip = 0; chip < 4; chip++) {
for (int pin = 0; pin < 16; pin++) {
int globalPin = chip * 16 + pin; // 0~63
bool inputState = inputArray[chip]->read(pin);
// 0 = Signal present (connected to GND), relay ON (output LOW)
// 1 = No signal, relay OFF (output HIGH)
outputArray[chip]->write(pin, inputState ? HIGH : LOW);
delay(200); // Slight delay to avoid excessive reading
6-input-trigger-output.zip (Size: 1.17 KB / Downloads: 679)
6-input-trigger-output.ino.merged.zip (Size: 192.34 KB / Downloads: 660)
