Threads: 1
05-03-2025, 11:59 AM
Hello. I'm a newbie so please bear with me. I would not like to damage the controller by incorrect connection.
Is the connection shown in the diagram correct?
( I'm using esphome.)
Threads: 1,473
yellow ouptut 0-5v signal?
Threads: 1
Water pressure - 0-5V signal (depending on pressure value)
Flow sensor- gives 5V pulse during water flow
Threads: 1,473
water presure wire is correct.
flow sensor connect to "1-wire GPIO".
then you can config by esphome yaml or write your own arduino source code.
Threads: 1
thank you for your answer. I understand that I will no longer be able to connect a temperature sensor in this case?
Threads: 1,473
you can connect sht30 i2c temperature sensor to i2c extender.
