"KCS" v2.2.13 firmware BIN file download
v2.2.13 improvement:
Fix MQTT message comma bug
.zip   KCS_KC868_A2_V2.2.13.zip (Size: 794.85 KB / Downloads: 445)
.zip   KCS_KC868_A4_V2.2.13.zip (Size: 781.72 KB / Downloads: 440)
.zip   KCS_KC868_A4S_V2.2.13.zip (Size: 805.62 KB / Downloads: 422)
.zip   KCS_KC868_A6_V2.2.13.zip (Size: 779.97 KB / Downloads: 661)
.zip   KCS_KC868_A8_V2.2.13.zip (Size: 788.75 KB / Downloads: 513)
.zip   KCS_KC868_A8M_V2.2.13.zip (Size: 805.18 KB / Downloads: 407)
.zip   KCS_KC868_A8S_V2.2.13.zip (Size: 806.51 KB / Downloads: 439)
.zip   KCS_KC868_A16_V2.2.13.zip (Size: 796.21 KB / Downloads: 665)
.zip   KCS_KC868_A16S_V2.2.13.zip (Size: 806.75 KB / Downloads: 426)
.zip   KCS_KC868_A32_V2.2.13.zip (Size: 786.52 KB / Downloads: 431)
.zip   KCS_KC868_A32M_V2.2.13.zip (Size: 804.42 KB / Downloads: 410)
.zip   KCS_KC868_A64_V2.2.13.zip (Size: 786.48 KB / Downloads: 397)
.zip   KCS_KC868_A128_V2.2.13.zip (Size: 786.5 KB / Downloads: 427)
.zip   KCS_KC868_AG_V2.2.13.zip (Size: 764.46 KB / Downloads: 456)
.zip   KCS_KC868_AI_V2.2.13.zip (Size: 788.97 KB / Downloads: 412)
.zip   KCS_KC868_AIO_V2.2.13.zip (Size: 806.06 KB / Downloads: 422)
.zip   KCS_KC868_AK_V2.2.13.zip (Size: 766.99 KB / Downloads: 390)
.zip   KCS_KC868_AM_V2.2.13.zip (Size: 781.92 KB / Downloads: 412)
.zip   KCS_KC868_AP_V2.2.13.zip (Size: 784.33 KB / Downloads: 386)
.zip   KCS_KC868_ASR_V2.2.13.zip (Size: 761.32 KB / Downloads: 415)
.zip   KCS_KC868_E16S_V2.2.13.zip (Size: 790.98 KB / Downloads: 427)
.zip   KCS_KC868_UAIR_V2.2.13.zip (Size: 767.68 KB / Downloads: 375)
hello,
I'm having a problem with A128,
I have 2 inputs that after a long time On, suddenly get off without triggering IFTTT events.
At all I have 30 IFTTT rules, and it does not take a lot of memory...
even the KCS monitor stays off the inputs even having signal.. then I only restart the board, and all works fine
can you test with esphome yaml?
what function you wanted?
The main function that only works with ifttt is to only turn on an output when 6 inputs are true.
you can enable IFTTT "AND" logical.
Hi, I just tested this new version (2.2.13). The temperature sensors do not update in mqtt after varying their value. will it be possible to have this working later?
Thanks!
you need to set the "threshold" in sensor webpage firstly, for example, input "0.1". that means , if temperature changed 0.1c will feedback to mqtt.
(06-22-2025, 11:33 PM)admin Wrote: you need to set the "threshold" in sensor webpage firstly, for example, input "0.1". that means , if temperature changed 0.1c will feedback to mqtt.
Perfect, it works. Cool
Thanks
I'm having trouble receiving feedback for MQTT!
I'm using a KC868-A4 Rev 1.2.5 board with the new version (2.2.14). In the KCS menu under System, I activated the option to automatically send ADC values.
Then I went to the Motinor, ADC menu, in channel settings and used the following values:
unit: psi
Custom value1 = 0
Custom value2 = 0
Threshold = 0.1
And I'm not getting feedback for MQTT!
Do I have to revert the version to 2.2.13?
Custom value2 should set a value, NOT 0
for example, if you want set the ranage is 0-5v, so that:
unit: v
Custom value1 = 0
Custom value2 = 5
Threshold = 0.1
