Threads: 2
Hello.
Working on a project with LED output necessary. Have loaded your firmware if I turn on any put on 9-16 LED light up...Connected to output 9
Ground of LED on 9 common on 3v.
Threads: 2
I have an LED wired into output 9...the LED common + is wired into 3V the -/ground is working into output. If I toggle output 10 the LED lights up same for 11,12 etc etc when I only want it to work on output 9
Threads: 1,560
A16 output 12-24V DC, not output 3V DC. i suggest you draw a diagram on paper how you wire, so that we can understand you.
Threads: 1,560
i don't understand , please draw a diagram on paper is better to understand.
