KC868-A128 INPUT toggle OUTPUT ESPhome yaml
  friendly_name: a128
esp32:
  board: esp32dev
  framework:
    type: arduino
# Example configuration entry
   - id: bus_a
     sda: 5
     scl: 16
     frequency: 400kHz
   - id: bus_b
     sda: 15
     scl: 4
     frequency: 400kHz
   type: LAN8720
   mdc_pin: GPIO23
   mdio_pin: GPIO18
   clk_mode: GPIO17_OUT
   phy_addr: 0
  # Optional manual IP
  # manual_ip:
  #   static_ip: 192.168.1.198
  #   gateway: 192.168.1.1
  #   subnet: 255.255.255.0
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_out_5'  # for output channel 65-80
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_out_6'  # for output channel 81-96
    i2c_id: bus_a
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_out_7'  # for output channel 97-112
    i2c_id: bus_a
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_out_8'  # for output channel 113-128
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for a128-input channel 1-16
    i2c_id: bus_b
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a128-input channel 17-32
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for a128-input channel 33-48
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for a128-input channel 49-64
    i2c_id: bus_b
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_5'  # for a128-input channel 65-80
    i2c_id: bus_b
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_6'  # for a128-input channel 81-96
    i2c_id: bus_b
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_in_7'  # for a128-input channel 97-112
    i2c_id: bus_b
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_in_8'  # for a128-input channel 113-128
    i2c_id: bus_b
    address: 0x23
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_3
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_4
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_5
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_6
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_7
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_8
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
# Individual inputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light1
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light2
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light3
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light4
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light5
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light6
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light7
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light8
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light9
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light10
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light11
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light12
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light13
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light14
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light15
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light16
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light17
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light18
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light19
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light20
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light21
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light22
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light23
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light24
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light25
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light26
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light27
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light28
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light29
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light30
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light31
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light32
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light33
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light34
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light35
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light36
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light37
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light38
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light39
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light40
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light41
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light42
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light43
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light44
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light45
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light46
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light47
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light48
      pcf8574: pcf8574_hub_in_4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light49
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light50
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light51
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light52
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light53
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light54
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light55
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light56
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light57
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light58
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light59
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light60
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light61
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light62
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light63
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light64
      pcf8574: pcf8574_hub_in_5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light65
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light66
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light67
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light68
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light69
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light70
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light71
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light72
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light73
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light74
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light75
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light76
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light77
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light78
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light79
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light80
      pcf8574: pcf8574_hub_in_6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light81
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light82
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light83
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light84
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light85
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light86
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light87
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light88
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light89
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light90
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light91
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light92
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light93
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light94
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light95
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light96
      pcf8574: pcf8574_hub_in_7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light97
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light98
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light99
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light100
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light101
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light102
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light103
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light104
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light105
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light106
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light107
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light108
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light109
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light110
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light111
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light112
      pcf8574: pcf8574_hub_in_8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light113
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light114
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light115
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light116
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light117
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light118
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light119
      number: 7
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light120
      number: 8
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light121
      number: 9
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light122
      number: 10
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light123
      number: 11
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light124
      number: 12
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light125
      number: 13
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light126
      number: 14
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light127
      number: 15
      mode: INPUT
    on_press:
      then:
        - switch.toggle: light128
web_server:
  port: 80
yaml file download:
.txt   KC868-A128-HA-input-toggle-output.txt (Size: 50.21 KB / Downloads: 375)
firmware BIN file download (download at 0x0 address , directly to use):
.zip   a128-input-toggle-output.zip (Size: 418.19 KB / Downloads: 691)
after download firmware, ethernet will work as DHCP mode. find the IP address from your router, then use IP address login by web browser.
