Home Assistant 8-Channel Smart Dimmer – KC868-D8 MQTT Firmware
My sample For Dimmer controller MQTT - NODE RED code - Config yaml - Lovelace code - HACS - Slider button integration
.pdf   Home Assistant Dimmer MQTT NODE RED Lovelace.pdf (Size: 852 KB / Downloads: 944)
good job, thank you share with DIYer.
