06-17-2025, 12:26 PM
* MQTT example using W5500 and ESP32-S3
* Adapted from KinCony's W5500 TCP Server example
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// W5500 pin definitions
#define W5500_CS_PIN 15
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
// MAC address (must be unique)
// Static IP settings
IPAddress ip(192, 168, 3, 55);
IPAddress gateway(192, 168, 3, 1);
IPAddress dns(192, 168, 3, 1);
// MQTT broker settings
const char* mqtt_server = "192.168.3.100"; // 可改为你的服务器
const int mqtt_port = 1883;
const char* mqtt_topic = "kincony/test";
// Ethernet and MQTT clients
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
// MQTT callback
void mqttCallback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("]: ");
for (unsigned int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
void mqttReconnect() {
while (!mqttClient.connected()) {
Serial.print("Attempting MQTT connection...");
if (mqttClient.connect("KinConyClient")) {
Serial.println("connected");
mqttClient.subscribe(mqtt_topic); // 订阅主题
} else {
Serial.print("failed, rc=");
Serial.print(mqttClient.state());
Serial.println(" trying again in 5 seconds");
delay(5000);
// Reset W5500
digitalWrite(W5500_RST_PIN, LOW);
delay(100);
digitalWrite(W5500_RST_PIN, HIGH);
delay(100);
// Start SPI
Ethernet.init(W5500_CS_PIN);
Serial.print("IP Address: ");
mqttClient.setServer(mqtt_server, mqtt_port);
mqttClient.setCallback(mqttCallback);
unsigned long lastMsg = 0;
if (!mqttClient.connected()) {
mqttReconnect();
mqttClient.loop();
// Publish message every 10 seconds
unsigned long now = millis();
if (now - lastMsg > 10000) {
lastMsg = now;
const char* msg = "Hello from KinCony ESP32S3 board + W5500";
mqttClient.publish(mqtt_topic, msg);
Serial.println("Published message");
14-mqtt.zip (Size: 1.19 KB / Downloads: 391)
