KC868-A8 ESP32 I/O pin define in Arduino IDE
#define ANALOG_A1  32
#define ANALOG_A2  33
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Relay1 = pcf8574.pinMode(P0, OUTPUT);
Relay2 = pcf8574.pinMode(P1, OUTPUT);
Relay3 = pcf8574.pinMode(P2, OUTPUT);
Relay4 = pcf8574.pinMode(P3, OUTPUT);
Relay5 = pcf8574.pinMode(P4, OUTPUT);
Relay6 = pcf8574.pinMode(P5, OUTPUT);
Relay7 = pcf8574.pinMode(P6, OUTPUT);
Relay8 = pcf8574.pinMode(P7, OUTPUT);
Input_IIC_address 0x22
Input1 = pcf8574.pinMode(P0, INPUT);
Input2 = pcf8574.pinMode(P1, INPUT);
Input3 = pcf8574.pinMode(P2, INPUT);
Input4 = pcf8574.pinMode(P3, INPUT);
Input5 = pcf8574.pinMode(P4, INPUT);
Input6 = pcf8574.pinMode(P5, INPUT);
Input7 = pcf8574.pinMode(P6, INPUT);
Input8 = pcf8574.pinMode(P7, INPUT);
(for KC868-A8 PCB v1.6)
S1: GPIO14
S2: GPIO13
S3: GPIO32
S4: GPIO33
const int DI9 = 36
const int DI10 =39
RF433MHz wireless receiver: 15
RF433MHz wireless transmitter: 2
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
Hello, I have a KC868-A8, i configured it by YAML CONFIG, to control the 4 shutters work with physical switches.
When I operate the shutter from the Home Assistant dashboard, I get the percentage information for the opening level, but when I operate it with a physical switch, I don't get that information.
Configuration
    interlock: [relay06]
      pcf8574: pcf8574_hub_out_1
      number: 4
      mode: OUTPUT
    interlock: [relay05]
      number: 5
      mode: OUTPUT
    interlock: [relay08]
      number: 6
      mode: OUTPUT
    interlock: [relay07]
      number: 7
      mode: OUTPUT
    on_press:
      then:
        - switch.toggle: relay01
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay02
      number: 1
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay03
      number: 2
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay04
      number: 3
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay05
      number: 4
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay06
      number: 5
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay07
      number: 6
      mode: INPUT
    on_press:
      then:
        - switch.toggle: relay08
      number: 7
      mode: INPUT
cover:
  - platform: time_based
    open_action:
      - switch.turn_on: 'relay05'
    open_duration: 30sec
    close_action:
      - switch.turn_on: 'relay06'
    close_duration: 30sec
    stop_action:
      - switch.turn_off: 'relay05'
      - switch.turn_off: 'relay06'
    open_action:
      - switch.turn_on: 'relay07'
    open_duration: 20sec
    close_action:
      - switch.turn_on: 'relay08'
    close_duration: 20sec
    stop_action:
      - switch.turn_off: 'relay07'
      - switch.turn_off: 'relay08'
