06-23-2025, 05:20 AM
* Description:
* This Arduino program reads the state of two 16-channel PCF8575 I/O expanders
* and prints the combined state of all 32 input pins to the Serial Monitor.
* Each pin state is represented as a bit in a 32-bit value (printed in binary format).
* Pin Definitions:
* - SDA: GPIO 48
* - SCL: GPIO 47
* PCF8575 I2C Addresses:
* - 0x24: input pins 1~16
* - 0x25: input pins 17~32
#include "Arduino.h"
#include "PCF8575.h"
#include <Wire.h>
// Define I2C pins
#define I2C_SDA 48 // SDA pin
#define I2C_SCL 47 // SCL pin
// Create PCF8575 instances
PCF8575 pcf8575_IN1(0x24); // Inputs 1~16
PCF8575 pcf8575_IN2(0x25); // Inputs 17~32
// Initialize I2C with custom SDA and SCL
Wire.begin(I2C_SDA, I2C_SCL);
// Initialize both PCF8575 expanders
pcf8575_IN1.begin();
pcf8575_IN2.begin();
Serial.println("KinCony F32 32 channel input state 0:ON 1:OFF");
uint32_t inputState = 0; // 32-bit variable to store combined state
// Read input pins 1~16
for (int pin = 0; pin < 16; pin++) {
if (pcf8575_IN1.read(pin)) {
inputState |= (1UL << pin); // Set corresponding bit
// Read input pins 17~32
if (pcf8575_IN2.read(pin)) {
inputState |= (1UL << (pin + 16)); // Set corresponding bit
for (int i = 31; i >= 0; i--) {
Serial.print(bitRead(inputState, i));
Serial.println();
delay(500); // Wait for 500 milliseconds
2-digital-input.zip (Size: 907 bytes / Downloads: 340)
2-digital-input.ino.merged.zip (Size: 192.33 KB / Downloads: 360)
