06-23-2025, 05:27 AM
* This program reads 32 input states from two PCF8575 I/O expanders
* and controls 32 relays via another two PCF8575 I/O expanders.
* When an input pin is LOW, the corresponding relay is turned ON (active LOW).
* When the input pin is HIGH, the corresponding relay is turned OFF.
* I2C Bus-1 Pin Definitions:
* - SDA: GPIO 48
* - SCL: GPIO 47
* I2C Addresses:
* - Output1-16: 0x20
* - Output17-32: 0x21
* - Input1-16: 0x24
* - Input17-32: 0x25
#include <Wire.h>
#include <PCF8575.h>
// Define I2C pins
#define I2C_SDA 48
#define I2C_SCL 47
// PCF8575 I2C addresses
#define OUTPUT1_ADDR 0x20
#define OUTPUT2_ADDR 0x21
#define INPUT1_ADDR 0x24
#define INPUT2_ADDR 0x25
// Create PCF8575 objects
PCF8575 pcf8575_IN1(INPUT1_ADDR); // Inputs 1~16
PCF8575 pcf8575_IN2(INPUT2_ADDR); // Inputs 17~32
PCF8575 pcf8575_OUT1(OUTPUT1_ADDR); // Outputs 1~16
PCF8575 pcf8575_OUT2(OUTPUT2_ADDR); // Outputs 17~32
// Initialize I2C with defined SDA and SCL
Wire.begin(I2C_SDA, I2C_SCL);
// Start serial communication
// Initialize all PCF8575 devices
pcf8575_IN1.begin();
pcf8575_IN2.begin();
pcf8575_OUT1.begin();
pcf8575_OUT2.begin();
// Turn off all relays at start (LOW = OFF)
pcf8575_OUT1.write(i, HIGH); // HIGH means OFF for relay
pcf8575_OUT2.write(i, HIGH);
Serial.println("System started: 32 inputs controlling 32 relays");
uint32_t inputState = 0;
// Read inputs 1~16
if (pcf8575_IN1.read(i)) {
inputState |= (1UL << i);
// Read inputs 17~32
if (pcf8575_IN2.read(i)) {
inputState |= (1UL << (i + 16));
// Control outputs 1~16
if (inputState & (1UL << i)) {
pcf8575_OUT1.write(i, HIGH); // Input HIGH -> Relay OFF
} else {
pcf8575_OUT1.write(i, LOW); // Input LOW -> Relay ON
// Control outputs 17~32
if (inputState & (1UL << (i + 16))) {
pcf8575_OUT2.write(i, HIGH); // Input HIGH -> Relay OFF
} else {
pcf8575_OUT2.write(i, LOW); // Input LOW -> Relay ON
delay(500);
6-input-trigger-output.zip (Size: 1 KB / Downloads: 391)
6-input-trigger-output.ino.merged.zip (Size: 181.75 KB / Downloads: 394)
