07-01-2025, 04:55 PM
Hello guys,
I have a problem with connecting KinCony KC868-A16v3 with scd41. How can I connect these devices to make HomeAssistant read the sensor data?
its testing platform.
Below are my settings:
platform: ESP32
board: esp32dev
- id: bus_a
sda: 9
scl: 10
frequency: 400kHz
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.XXXXXXX
gateway: 192.XXXXXX
subnet: 255.XXXXX
pcf8574:
address: 0x24
- id: 'pcf8574_hub_out_2' # for output channel 9-16
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
# Use pin number 1
number: 1
mode: OUTPUT
# Use pin number 2
number: 2
mode: OUTPUT
# Use pin number 3
number: 3
mode: OUTPUT
# Use pin number 4
number: 4
mode: OUTPUT
# Use pin number 5
number: 5
mode: OUTPUT
# Use pin number 6
number: 6
mode: OUTPUT
# Use pin number 7
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
# Use pin number 0
mode: OUTPUT
# Use pin number 1
number: 1
mode: OUTPUT
# Use pin number 2
number: 2
mode: OUTPUT
# Use pin number 3
number: 3
mode: OUTPUT
# Use pin number 4
number: 4
mode: OUTPUT
# Use pin number 5
number: 5
mode: OUTPUT
# Use pin number 6
number: 6
mode: OUTPUT
# Use pin number 7
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_2
# Use pin number 0
mode: INPUT
# Use pin number 1
number: 1
mode: INPUT
# Use pin number 2
number: 2
mode: INPUT
# Use pin number 3
number: 3
mode: INPUT
# Use pin number 4
number: 4
mode: INPUT
# Use pin number 5
number: 5
mode: INPUT
# Use pin number 6
number: 6
mode: INPUT
# Use pin number 7
number: 7
mode: INPUT
pcf8574: pcf8574_hub_in_1
# Use pin number 0
mode: INPUT
# Use pin number 1
number: 1
mode: INPUT
# Use pin number 2
number: 2
mode: INPUT
# Use pin number 3
number: 3
mode: INPUT
# Use pin number 4
number: 4
mode: INPUT
# Use pin number 5
number: 5
mode: INPUT
# Use pin number 6
number: 6
mode: INPUT
# Use pin number 7
number: 7
mode: INPUT
one_wire:
pin: GPIO14
- platform: dallas_temp
address: 0x803c8504578d3328
update_interval: 5s
