KC868 server16 and GSM module
My KC868 server16 has a GSM module. How do I use the GSM module in server16 to do sms and calls
do you use by home asisstant or Node-red or other software solution?
(07-01-2025, 10:46 PM)fdcemb5 Wrote: My KC868 server16 has a GSM module. How do I use the GSM module in server16 to do sms and calls
We are using Home Assistant
you can use home assistant send command by UART serial port using SIM7600 AT command.
(07-02-2025, 04:09 AM)admin Wrote: you can use home assistant send command by UART serial port using SIM7600 AT command.
Kindly send me the link for this or samples
Can the GSM module in KC868 server16 fit into A32 Pro Smart Controller?
Can the GSM module in KC868 server16 fit into A32 Pro Smart Controller?   -- Yes, use by same GSM module.
here is AT command document for SIM7600E
.pdf   SIM7500_SIM7600 Series_AT Command Manual_V2.00.pdf (Size: 2.72 MB / Downloads: 291)
All the USB in server16 is disabled after HA installation. How do I enable them
https://www.kincony.com/forum/showthread.php?tid=1980
(07-02-2025, 06:06 AM)fdcemb5 Wrote:
(07-02-2025, 04:09 AM)admin Wrote: You can use Home Assistant to send commands via the UART serial port using the SIM7600 AT command.
I cannot find any example on how to use Home Assistant to send commands via the UART serial port using the SIM7600 AT command. Kindly help with a concrete example
