Threads: 1
Hi, I plugged my board via ethernet to my router, but it has no IP, my net is 192.168.2.*.
Anyway, I would like to flash my own code witn ESP32 python to enable / disable relays via http, how to set up a static ip? and which are the gpio pins to enable / disable relays?
Thank you
Threads: 1,593
because new board no firmware inside of ESP32, you need download KCS v2 firmware by usb-c cable firstly, here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
if you want write your own python code, sure, it's ok.
Threads: 1
(07-03-2025, 07:59 AM)admin Wrote: because new board no firmware inside of ESP32, you need download KCS v2 firmware by usb-c cable firstly, here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
thanks for the reply, but I use linux and in the zip there is no "KC868-A64-V1.0.9.bin" file there are:
demo_cn.bin (i suppose that is chinese version)
demo_en.bin (i suppose that is english version)
NOTE_test_board_fw_v.10
Threads: 1
07-03-2025, 10:00 PM
(This post was last modified: 07-04-2025, 08:40 AM by zital.)
I see the relay 1 is 15 pin and relay 2 pin is 2 here:
https://www.kincony.com/forum/showthread.php?tid=2691
well, I flashed the ESP32 using idd.py and I build this code and works fine, but is using wifi, i need to work with ethernet, if someone can helps me I really appreciated:
PHP Code: #include <string.h> #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "esp_wifi.h" #include "esp_event.h" #include "esp_log.h" #include "nvs_flash.h" #include "esp_netif.h" #include "esp_http_server.h" #include "driver/gpio.h"
// Wi-Fi credentials #define WIFI_SSID "WIFI_NAME" #define WIFI_PASS "WIFI_PASSWORD"
// GPIOs for relays #define RELAY1_GPIO GPIO_NUM_15 #define RELAY2_GPIO GPIO_NUM_2
static const char *TAG = "relay_server";
// Relay control static void set_relay(int relay_num, bool on) { gpio_num_t gpio = (relay_num == 1) ? RELAY1_GPIO : RELAY2_GPIO; gpio_set_level(gpio, on ? 0 : 1); // Active LOW }
// HTTP Handlers esp_err_t relay1_on_handler(httpd_req_t *req) { set_relay(1, false); httpd_resp_send(req, "Relay 1 ON", HTTPD_RESP_USE_STRLEN); return ESP_OK; }
esp_err_t relay1_off_handler(httpd_req_t *req) { set_relay(1, true); httpd_resp_send(req, "Relay 1 OFF", HTTPD_RESP_USE_STRLEN); return ESP_OK; }
esp_err_t relay2_on_handler(httpd_req_t *req) { set_relay(2, false); httpd_resp_send(req, "Relay 2 ON", HTTPD_RESP_USE_STRLEN); return ESP_OK; }
esp_err_t relay2_off_handler(httpd_req_t *req) { set_relay(2, true); httpd_resp_send(req, "Relay 2 OFF", HTTPD_RESP_USE_STRLEN); return ESP_OK; }
esp_err_t root_handler(httpd_req_t *req) { const char* resp_str = "ESP32 Relay Control:\n" "/relay1/on or /relay1/off\n" "/relay2/on or /relay2/off\n"; httpd_resp_send(req, resp_str, HTTPD_RESP_USE_STRLEN); return ESP_OK; }
// HTTP Server httpd_handle_t start_webserver(void) { httpd_config_t config = HTTPD_DEFAULT_CONFIG(); httpd_handle_t server = NULL;
if (httpd_start(&server, &config) == ESP_OK) { httpd_uri_t root = { .uri = "/", .method = HTTP_GET, .handler = root_handler, .user_ctx = NULL }; httpd_uri_t relay1_on = { .uri = "/relay1/on", .method = HTTP_GET, .handler = relay1_on_handler, .user_ctx = NULL }; httpd_uri_t relay1_off = { .uri = "/relay1/off", .method = HTTP_GET, .handler = relay1_off_handler, .user_ctx = NULL }; httpd_uri_t relay2_on = { .uri = "/relay2/on", .method = HTTP_GET, .handler = relay2_on_handler, .user_ctx = NULL }; httpd_uri_t relay2_off = { .uri = "/relay2/off", .method = HTTP_GET, .handler = relay2_off_handler, .user_ctx = NULL };
httpd_register_uri_handler(server, &root); httpd_register_uri_handler(server, &relay1_on); httpd_register_uri_handler(server, &relay1_off); httpd_register_uri_handler(server, &relay2_on); httpd_register_uri_handler(server, &relay2_off); }
return server; }
// Wi-Fi event handler static void wifi_event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data) { if (event_id == WIFI_EVENT_STA_START) { esp_wifi_connect(); } else if (event_id == WIFI_EVENT_STA_DISCONNECTED) { esp_wifi_connect(); } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) { ESP_LOGI(TAG, "Connected with IP"); start_webserver(); } }
// Initialize Wi-Fi void wifi_init(void) { esp_netif_init(); esp_event_loop_create_default(); esp_netif_create_default_wifi_sta();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT(); esp_wifi_init(&cfg);
esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL); esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler, NULL);
wifi_config_t wifi_config = { .sta = { .ssid = WIFI_SSID, .password = WIFI_PASS, }, }; esp_wifi_set_mode(WIFI_MODE_STA); esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config); esp_wifi_start(); }
// GPIO setup void relay_gpio_init() { gpio_config_t io_conf = { .pin_bit_mask = (1ULL << RELAY1_GPIO) | (1ULL << RELAY2_GPIO), .mode = GPIO_MODE_OUTPUT, .pull_up_en = 0, .pull_down_en = 0, .intr_type = GPIO_INTR_DISABLE, }; gpio_config(&io_conf);
// Default state: OFF gpio_set_level(RELAY1_GPIO, 0); gpio_set_level(RELAY2_GPIO, 0); }
void app_main(void) { ESP_ERROR_CHECK(nvs_flash_init()); relay_gpio_init(); wifi_init(); }
To enable disable relays (you can see the IP in the logs):
http://IP/relay1/on
http://IP/relay1/off
http://IP/relay2/on
http://IP/relay2/off
Threads: 1,593
maybe you can use for test:
#include "esp_eth.h"
#include "esp_mac.h"
#include "esp_eth_phy.h"
#include "esp_eth_phy_lan8720.h"
#include "esp_eth_driver.h"
// Relay GPIOs
// Ethernet config
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
#define ETH_TYPE ETH_PHY_LAN8720
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
static const char *TAG = "ethernet_relay";
// Relay Control
// HTTP Handlers
return ESP_OK;
set_relay(1, true);
return ESP_OK;
return ESP_OK;
set_relay(2, true);
return ESP_OK;
"ESP32 Relay Control (Ethernet):\n"
return ESP_OK;
// HTTP Server
httpd_register_uri_handler(server, &(httpd_uri_t){.uri="/", .method=HTTP_GET, .handler=root_handler});
httpd_register_uri_handler(server, &(httpd_uri_t){.uri="/relay1/on", .method=HTTP_GET, .handler=relay1_on_handler});
httpd_register_uri_handler(server, &(httpd_uri_t){.uri="/relay1/off", .method=HTTP_GET, .handler=relay1_off_handler});
httpd_register_uri_handler(server, &(httpd_uri_t){.uri="/relay2/on", .method=HTTP_GET, .handler=relay2_on_handler});
httpd_register_uri_handler(server, &(httpd_uri_t){.uri="/relay2/off", .method=HTTP_GET, .handler=relay2_off_handler});
return server;
// Ethernet Event Handler
static void eth_event_handler(void *arg, esp_event_base_t event_base,
int32_t event_id, void *event_data) {
switch (event_id) {
case ETHERNET_EVENT_CONNECTED:
ESP_LOGI(TAG, "Ethernet Connected");
break;
case ETHERNET_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "Ethernet Disconnected");
break;
case ETHERNET_EVENT_START:
ESP_LOGI(TAG, "Ethernet Started");
break;
case ETHERNET_EVENT_STOP:
ESP_LOGI(TAG, "Ethernet Stopped");
break;
default:
break;
static void got_ip_event_handler(void *arg, esp_event_base_t event_base,
ip_event_got_ip_t *event = (ip_event_got_ip_t *) event_data;
ESP_LOGI(TAG, "Got IP Address: " IPSTR, IP2STR(&event->ip_info.ip));
start_webserver();
// Ethernet Initialization
void eth_init(void) {
ESP_ERROR_CHECK(esp_netif_init());
ESP_ERROR_CHECK(esp_event_loop_create_default());
esp_netif_config_t cfg = ESP_NETIF_DEFAULT_ETH();
esp_netif_t *eth_netif = esp_netif_new(&cfg);
esp_eth_mac_t *mac = esp_eth_mac_new_esp32();
eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
phy_config.phy_addr = ETH_ADDR;
phy_config.reset_gpio_num = ETH_POWER_PIN;
esp_eth_phy_t *phy = esp_eth_phy_new_lan8720(&phy_config);
esp_eth_handle_t eth_handle = NULL;
esp_eth_config_t eth_config = ETH_DEFAULT_CONFIG(mac, phy);
ESP_ERROR_CHECK(esp_eth_driver_install(ð_config, ð_handle));
ESP_ERROR_CHECK(esp_netif_attach(eth_netif, esp_eth_new_netif_glue(eth_handle)));
ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ESP_EVENT_ANY_ID, ð_event_handler, NULL));
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &got_ip_event_handler, NULL));
ESP_ERROR_CHECK(esp_eth_start(eth_handle));
// GPIO Initialization
.pull_up_en = 0,
.pull_down_en = 0,
// Main
relay_gpio_init();
eth_init();
Threads: 1
(07-04-2025, 01:03 AM)admin Wrote: maybe you can use for test:
I have a compilation error:
Code: [zital@s-400 zitalki-esp32]$ idf.py build
/home/projects/zitalki-esp32/main/main.c:13:10: fatal error: esp_eth_phy_lan8720.h: No such file or directory
13 | #include "esp_eth_phy_lan8720.h"
compilation terminated.
[4/9] Completed 'bootloader'
ninja: build stopped: subcommand failed.
ninja failed with exit code 1, output of the command is in the /home/projects/zitalki-esp32/build/log/idf_py_stderr_output_35496 and /home/projects/zitalki-esp32/build/log/idf_py_stdout_output_35496
Threads: 1,593
sorry, about python code, you need check by yourself.
Threads: 1
this code of python in esp32 works:
Code: import network
import socket
from machine import Pin
import time
# Wi-Fi credentials
WIFI_SSID = "WIFI_NAME"
WIFI_PASS = "WIFI_PASSWORD"
# GPIO pins for relays (active LOW)
RELAY1_GPIO = 15
RELAY2_GPIO = 2
# Setup GPIOs
relay1 = Pin(RELAY1_GPIO, Pin.OUT, value=1)
relay2 = Pin(RELAY2_GPIO, Pin.OUT, value=1)
def set_relay(relay_num, on):
gpio = relay1 if relay_num == 1 else relay2
gpio.value(0 if on else 1)
# Connect to Wi-Fi
def wifi_connect():
wlan = network.WLAN(network.STA_IF)
wlan.active(True)
if not wlan.isconnected():
print(f"Connecting to {WIFI_SSID} ...")
wlan.connect(WIFI_SSID, WIFI_PASS)
while not wlan.isconnected():
time.sleep(0.5)
print(".", end="")
print("\nConnected, IP:", wlan.ifconfig()[0])
# HTTP response helpers
def http_response(conn, body):
conn.send(b"HTTP/1.1 200 OK\r\n")
conn.send(b"Content-Type: text/plain\r\n")
conn.send(b"Content-Length: %d\r\n" % len(body))
conn.send(b"\r\n")
conn.send(body)
# HTTP server
def start_server():
addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
s = socket.socket()
s.bind(addr)
s.listen(1)
print("HTTP server listening on port 80")
while True:
try:
conn, addr = s.accept()
print("Client connected from", addr)
request = conn.recv(1024).decode()
print("Request:", request)
path = ""
try:
path = request.split(" ")[1]
except:
pass
if path == "/":
body = (
elif path == "/relay1/on":
set_relay(1, True)
body = "Relay 1 ON"
elif path == "/relay1/off":
set_relay(1, False)
body = "Relay 1 OFF"
elif path == "/relay2/on":
set_relay(2, True)
body = "Relay 2 ON"
elif path == "/relay2/off":
set_relay(2, False)
body = "Relay 2 OFF"
else:
body = "Invalid path"
http_response(conn, body.encode())
conn.close()
except Exception as e:
print("Error handling connection:", e)
# Main app
wifi_connect()
start_server()
Now, I'm going to try to do it with Ethernet
