Lesson18- how to use UDP communication with KC868-A8 by ethernet
Arduino IDE source code:
.zip   LAN8720_UDP.zip (Size: 902 bytes / Downloads: 1,691)
if I want to send a UDP packet when I press an input or button. Can be done?
What would be the solution?
Thanks
sure, our arduino source code demo already can send and receive package by UDP. you just add IF DI is pressed THEN use UDP send function is ok.
Executei exatamente o mesmo código e não funcionou. minha porta ethernet nem da sinal de vida. O Retorno no monitor serial me da  ip 0.0.0.0.
Alguma sugestão?
take photo of your problem.
