Threads: 30
My KC868-server16 refused to boot, and it is just blinking as shown in the video. I have inserted the SD card into the standalone Raspberry Pi 4 module, and it booted. I am wondering what to do next. I have tried several times to reboot without success.
Threads: 1,388
you can try to remove CM4 from bottom pcb, re plugin again, make sure have a good contact.
Threads: 1,388
do you means after installed home assistant firmware to SD card. after reboot , can't login? please check ip of CM4 in your router, use IP address to login, not use by domain.
