Loxone RS485
I noticed that Kincony also has RS485 communication, it is more difficult, but it seems safer to me without dependence on the local network.
Does anyone have experience with this integration please?
Maybe first question it's Modbus RS485 or "RAW" RS485?
I am new owner "KC868-A32M 32 Channel ESP32 MOSFET Board".
I'm currently struggling to see it on the network at all, it may have DHCP set up, but I can't see it anywhere on the network after connecting.
do you have downloaded newest KCS v2 firmware by usb-c cable firstly?
Hi thanks, trying to upoad but now 1 hour still in progress Ithink it's not succes ...
you have not selected first item. please see our photo, step-3:
[Image: esp32_download_tool_2.png]
Maybe this doc?
http://kincony.com/forum/attachment.php?aid=2240
Thanks, done, but what is please next step with connection modbus-485 only? Do you have tech docu?
Maybe this doc?
yes
thanks communicatino is working but now I have problem, ho to please connect relay Finder 34.51.7.024.0010 to the board? It's 24V relay, now I am not sure now if it's possible to use 24V DC relay with this board KC868-A32M. Because in case using V-in connected to 24V power supply and to A1 relay and A2 relay to ouput 1, there is only 5V DC voltage on relay.
Am I doing something wrong or?
Marek
A32M can work with 24v power supply, then mosfet output terminal connect to 24v load.
you can see this video tour talked about how to use digital output, it as same as A32M board: https://youtu.be/laNqLfuLVQM
