Kincony Server-Mini
Hello, we just started with kincony, and need help to control the server-mini relay and i/O-ports.
please send us a help to control these ports. Will it work with udp ?
Thanks for short reply with solution to control these ports.
if you want work with home assistant, just see this video: https://youtu.be/J5GRh7GkmfQ
if you want use by private protocol, you can write your own code or install node-red on CM4.
