B24M ESPHome yaml for home assistant with tuya
  friendly_name: b24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.1.0
#logger:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
pcf8574:
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 & ouptut 1-8
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: vyznobv3bahs2pwl
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
      pcf8574: pcf8574_hub_in_1
      number: 8
      mode: INPUT
  - platform: tuya_wifi_mcu
    dp_id: 125
    bind_binary_sensor_id: b24_input01
    internal: true
      number: 9
      mode: INPUT
    dp_id: 126
    bind_binary_sensor_id: b24_input02
    internal: true
      number: 10
      mode: INPUT
    dp_id: 127
    bind_binary_sensor_id: b24_input03
    internal: true
      number: 11
      mode: INPUT
    dp_id: 128
    bind_binary_sensor_id: b24_input04
    internal: true
      number: 12
      mode: INPUT
    dp_id: 129
    bind_binary_sensor_id: b24_input05
    internal: true
      number: 13
      mode: INPUT
    dp_id: 130
    bind_binary_sensor_id: b24_input06
    internal: true
      number: 14
      mode: INPUT
    dp_id: 131
    bind_binary_sensor_id: b24_input07
    internal: true
      number: 15
      mode: INPUT
    dp_id: 132
    bind_binary_sensor_id: b24_input08
    internal: true
      mode: INPUT
    dp_id: 133
    bind_binary_sensor_id: b24_input09
    internal: true
      number: 1
      mode: INPUT
    dp_id: 134
    bind_binary_sensor_id: b24_input10
    internal: true
      number: 2
      mode: INPUT
    dp_id: 135
    bind_binary_sensor_id: b24_input11
    internal: true
      number: 3
      mode: INPUT
    dp_id: 136
    bind_binary_sensor_id: b24_input12
    internal: true
      number: 4
      mode: INPUT
    dp_id: 137
    bind_binary_sensor_id: b24_input13
    internal: true
      number: 5
      mode: INPUT
    dp_id: 138
    bind_binary_sensor_id: b24_input14
    internal: true
      number: 6
      mode: INPUT
    dp_id: 139
    bind_binary_sensor_id: b24_input15
    internal: true
      number: 7
      mode: INPUT
    dp_id: 140
    bind_binary_sensor_id: b24_input16
    internal: true
      pcf8574: pcf8574_hub_in_out_1
      mode: INPUT
    dp_id: 141
    bind_binary_sensor_id: b24_input17
    internal: true
      number: 1
      mode: INPUT
    dp_id: 142
    bind_binary_sensor_id: b24_input18
    internal: true
      number: 2
      mode: INPUT
    dp_id: 143
    bind_binary_sensor_id: b24_input19
    internal: true
      number: 3
      mode: INPUT
    dp_id: 144
    bind_binary_sensor_id: b24_input20
    internal: true
      number: 4
      mode: INPUT
    dp_id: 145
    bind_binary_sensor_id: b24_input21
    internal: true
      number: 5
      mode: INPUT
    dp_id: 146
    bind_binary_sensor_id: b24_input22
    internal: true
      number: 6
      mode: INPUT
    dp_id: 147
    bind_binary_sensor_id: b24_input23
    internal: true
      number: 7
      mode: INPUT
    dp_id: 148
    bind_binary_sensor_id: b24_input24
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
      number: 7
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      mode: OUTPUT
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b24_output01"
      number: 9
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "b24_output02"
      number: 10
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "b24_output03"
      number: 11
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "b24_output04"
      number: 12
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "b24_output05"
      number: 13
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "b24_output06"
      number: 14
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "b24_output07"
      number: 15
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "b24_output08"
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "b24_output09"
      number: 1
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "b24_output10"
      number: 2
      mode: OUTPUT
    dp_id: 111
    internal: true
    bind_switch_id: "b24_output11"
      number: 3
      mode: OUTPUT
    dp_id: 112
    internal: true
    bind_switch_id: "b24_output12"
      number: 4
      mode: OUTPUT
    dp_id: 113
    internal: true
    bind_switch_id: "b24_output13"
      number: 5
      mode: OUTPUT
    dp_id: 114
    internal: true
    bind_switch_id: "b24_output14"
      number: 6
      mode: OUTPUT
    dp_id: 115
    internal: true
    bind_switch_id: "b24_output15"
      number: 7
      mode: OUTPUT
    dp_id: 116
    internal: true
    bind_switch_id: "b24_output16"
      number: 8
      mode: OUTPUT
    dp_id: 117
    internal: true
    bind_switch_id: "b24_output17"
      number: 9
      mode: OUTPUT
    dp_id: 118
    internal: true
    bind_switch_id: "b24_output18"
      number: 10
      mode: OUTPUT
    dp_id: 119
    internal: true
    bind_switch_id: "b24_output19"
      number: 11
      mode: OUTPUT
    dp_id: 120
    internal: true
    bind_switch_id: "b24_output20"
      number: 12
      mode: OUTPUT
    dp_id: 121
    internal: true
    bind_switch_id: "b24_output21"
      number: 13
      mode: OUTPUT
    dp_id: 122
    internal: true
    bind_switch_id: "b24_output22"
      number: 14
      mode: OUTPUT
    dp_id: 123
    internal: true
    bind_switch_id: "b24_output23"
      number: 15
      mode: OUTPUT
    dp_id: 124
    internal: true
    bind_switch_id: "b24_output24"
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B24");
download yaml file:
.txt   B24-HA-with-Tuya.txt (Size: 19.26 KB / Downloads: 111)
