07-31-2025, 07:00 AM
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 40
* - GPIO 48
* - GPIO 47
* - GPIO 7
* Hardware Requirements:
// Define the GPIO pins to be monitored
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_40 40
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_7 7
// Create an array to hold the GPIO pin numbers
const int monitoredPins[] = {
GPIO_PIN_13,
GPIO_PIN_14,
GPIO_PIN_21,
GPIO_PIN_40,
GPIO_PIN_48,
GPIO_PIN_47,
GPIO_PIN_7
const int pinCount = sizeof(monitoredPins) / sizeof(monitoredPins[0]);
bool prevState[pinCount] = {false};
Serial.begin(115200); // Initialize the serial monitor
while (!Serial); // Wait for serial monitor to open
// Set each monitored pin as input
for (int i = 0; i < pinCount; i++) {
pinMode(monitoredPins[i], INPUT);
bool currentState = digitalRead(monitoredPins[i]);
if (currentState != prevState[i]) {
Serial.print("GPIO ");
Serial.print(monitoredPins[i]);
Serial.print(" changed to ");
Serial.println(currentState ? "HIGH" : "LOW");
prevState[i] = currentState;
delay(100); // Delay to reduce serial flooding
5-free-gpio-state.zip (Size: 924 bytes / Downloads: 264)
5-free-gpio-state.ino.merged.zip (Size: 181.63 KB / Downloads: 253)
