KC 868-A16 RS485
Exclamation
I am trying to connect a pressure sensor to my KC868-A16 board using RS485 communication. The sensor works via Modbus RTU, and I want the KC868-A16 to act as the master.
Here are the issues I am facing:
  1. On the web configuration page of KC868, I can see General Protocol and Custom Protocol, but I am not sure which one I should use for the pressure sensor, since it is not listed in the default devices.
  2. I have tested the RS485 line with a USB-RS485 adapter and Modbus Poll, and I can see the sensor replying with values (e.g. 500, 0, 500, …). So the sensor is working correctly.
  3. When I try to scan for slave IDs from Python via the KC RS485, I only get timeout errors. TX is active, but RX never receives data.
  4. I have already checked the wiring (A↔A, B↔B, and GND connected), baudrate, parity, stopbits, and slave ID, but still no communication between KC and the pressure sensor.
So my questions are:
  • How should I configure KC868 in the web interface to read registers from the pressure sensor?
  • Do I need to use General Protocol or Custom Protocol?
  • Is there any example of how to set the registers mapping for an external Modbus RTU sensor?
Thanks in advance for your help!
KCS firmware not use for customize RS485 sensor.
if you want use for home assistant, i suggest you config by ESPHome via modbus controller. You can also write your own Arduino code for your project.
