[arduino code examples for DM16]-02 Read digital input ports state
* KinCony DM16 16-Channel Digital Input Reader using PCF8575
* This Arduino sketch reads the state of 16 digital input channels from a
* PCF8575 I/O expander over I2C and prints their status to the serial monitor.
* Input logic:
*   - Input 0 = ON
*   - Input 1 = OFF (with pull-up logic)
* Hardware:
*   - PCF8575 I/O Expander (I2C Address: 0x22)
*   - Custom input pin mapping as defined below
*   - I2C SDA pin: GPIO8
*   - I2C SCL pin: GPIO18
* Author: KinCony IoT
* Website: https://www.kincony.com
* License: MIT License
#include <Wire.h>
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 8   // SDA pin
#define I2C_SCL 18  // SCL pin
// Set the I2C address for PCF8575
PCF8575 pcf8575_IN1(0x22); // 0x22 is the I2C address for the DM16 module
    // Initialize I2C with specified SDA and SCL pins
    Wire.begin(I2C_SDA, I2C_SCL);
    // Start communication with PCF8575 device
    pcf8575_IN1.begin();
    Serial.println("KinCony DM16 16 channel input state 0:ON  1:OFF");
    // Define custom pin read order to match hardware mapping
    uint8_t pin_order[16] = {
        8, 9, 10, 11, 12, 13, 14, 15,
        0, 1, 2, 3, 4, 5, 6, 7
    // Loop through all 16 pins and read their state
        bool state = pcf8575_IN1.read(pin_order[i]); // Read pin state (HIGH or LOW)
        Serial.print(state); // Print state: 0 = ON, 1 = OFF
        Serial.print(" ");
    Serial.println(); // Print new line
    delay(500);       // Wait for 500ms before next read
.zip   2-digital-input.zip (Size: 995 bytes / Downloads: 253)
.zip   2-digital-input.ino.merged.zip (Size: 192.34 KB / Downloads: 245)
