Operating WLAN and Ethernet together
Confused  When I enter WLAN and Ethernet together in ESPHome, I get the following error message:
Can you please provide a code example?
(09-10-2025, 07:53 AM)JuDie07 Wrote: Confused  When I enter WLAN and Ethernet together in ESPHome, I get the following error message:
Unfortunately, ESPHome does not currently allow you to use both Ethernet and Wi-Fi at the same time.
You must use ONLY Ethernet or ONLY WIFI.
This is currently a limitation of ESPHome.
ESPHome can't use wifi and ethernet at the same time.
if you want, you can download KCS firmware, that's ok.
