09-15-2025, 01:18 AM
friendly_name: AIO-hybrid
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
#logger:
# hardware_uart: USB_SERIAL_JTAG
external_components:
- source:
type: git
ref: v1.1.0
uart:
# - id: uart_zsu
# baud_rate: 115200
# debug:
# direction: BOTH
# dummy_receiver: true
# after:
# timeout: 10ms
# sequence:
# - lambda: UARTDebug::log_string(direction, bytes);
# tx_pin: 15
#3 rx_pin: 48
- id: tuya_mcu_uart
tx_pin: GPIO39
rx_pin: GPIO38
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: 0x9gs3fuzgggwhi1
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
pcf8574:
- id: 'pcf8574_hub_output_1' # for output channel 5
i2c_id: bus_a
address: 0x26
- id: 'pcf8574_hub_input_1' # for input channel 1-12
i2c_id: bus_a
address: 0x24
pcf8575: true
# - platform: uart
# uart_id: uart_zsu
# name: "UART zigbee"
# data: [0x55, 0xaa, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x04] # ZSU zigbee module
pcf8574: pcf8574_hub_output_1
number: 3
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "AIO_hybrid_output01"
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
- platform: template
turn_on_action:
- remote_transmitter.transmit_pronto:
transmitter_id: ir1
data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0575 015B 0057 0016 0E6C"
pcf8574: pcf8574_hub_input_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
## without resistance on PCB
number: 40
inverted: false
inverted: false
mcp4728:
- id: dac_output
output:
- platform: mcp4728
mcp4728_id: dac_output
channel: A
vref: vdd
power_down: normal # default
- platform: mcp4728
channel: B
vref: vdd
- platform: mcp4728
channel: C
vref: vdd
- platform: mcp4728
channel: D
vref: vdd
light:
- platform: monochromatic
output: dimmer1
gamma_correct: 1.0
output: dimmer2
gamma_correct: 1.0
output: dimmer3
gamma_correct: 1.0
output: dimmer4
gamma_correct: 1.0
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "AIO-hybrid");
- platform: adc
pin: 5
name: "AIO_hybrid A1 Voltage"
update_interval: 55s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 7
name: "AIO_hybrid A2 Voltage"
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "AIO_hybrid A3 Current"
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "AIO_hybrid A4 Current"
attenuation: 11db
filters:
remote_receiver:
pin: 17
dump: all
remote_transmitter:
- id: ir1
pin: 14
carrier_duty_percent: 50%
web_server:
port: 80
AIO-hybrid_pin_define-HA-with-Tuya.txt (Size: 8.12 KB / Downloads: 185)
