[arduino code examples for AIO Hybrid]-01 Turn ON/OFF relay
* PCF8574 Relay Control Example
* Controls 5 relays connected to PCF8574 via I2C bus.
* Made By KinCony
* https://www.kincony.com
#include <Arduino.h>
#include <Wire.h>
#include "PCF8574.h"
// I2C pin definitions
#define I2C_SDA 8
#define I2C_SCL 18
// Create PCF8574 object with I2C address 0x26
PCF8574 pcf8574(0x26);
  delay(500);
  // Initialize I2C with specified SDA and SCL pins
  Wire.begin(I2C_SDA, I2C_SCL);
  // Set PCF8574 P3~P7 as OUTPUT (Relays)
  pcf8574.pinMode(P3, OUTPUT);
  pcf8574.pinMode(P4, OUTPUT);
  pcf8574.pinMode(P5, OUTPUT);
  pcf8574.pinMode(P6, OUTPUT);
  pcf8574.pinMode(P7, OUTPUT);
  if (pcf8574.begin()) {
    Serial.println("OK");
  } else {
    Serial.println("KO");
    while (1); // Stop if initialization fails
  // Turn OFF all relays at startup
  for (int pin = P3; pin <= P7; pin++) {
    pcf8574.digitalWrite(pin, LOW);
  // Turn ON all relays one by one
    pcf8574.digitalWrite(pin, HIGH);
    delay(500);
  delay(1000); // Keep all relays ON for a while
  delay(1000); // Keep all relays OFF for a while
.zip   1-relay.zip (Size: 724 bytes / Downloads: 632)
.zip   1-relay.ino.merged.zip (Size: 198.37 KB / Downloads: 570)
