09-15-2025, 01:28 AM
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 47
#define RS485_TXD 3
while (!Serial);
// Send a test message
rs485Serial.println("Hello from KinCony Controller!");
// Wait for a short period
delay(1000);
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
delay(2000);
4-RS485-Test.zip (Size: 766 bytes / Downloads: 279)
4-RS485-Test.ino.merged.zip (Size: 189.46 KB / Downloads: 302)
