09-15-2025, 01:29 AM
* Copyright (c) 2025 KinCony IoT
* https://www.kincony.com
* Description:
* This program generates a 38 kHz PWM signal on a specified GPIO pin
* using the ESP32-S3 LEDC hardware peripheral.
* The output can be used to drive an IR LED for infrared signal transmission.
#include <Arduino.h>
#include "driver/ledc.h"
#define IR_SEND_PIN 14 // GPIO pin connected to the IR LED
// Configure the LEDC timer
ledc_timer_config_t ledc_timer = {
.speed_mode = LEDC_LOW_SPEED_MODE, // Use low-speed mode
.duty_resolution = LEDC_TIMER_8_BIT, // 8-bit resolution (0-255)
.timer_num = LEDC_TIMER_0, // Select timer 0
.freq_hz = 38000, // Set frequency to 38 kHz
.clk_cfg = LEDC_AUTO_CLK // Automatically select the clock source
ledc_timer_config(&ledc_timer);
// Configure the LEDC channel
ledc_channel_config_t ledc_channel = {
.gpio_num = IR_SEND_PIN, // Output GPIO pin
.channel = LEDC_CHANNEL_0, // Channel 0
.intr_type = LEDC_INTR_DISABLE, // Disable interrupts
.timer_sel = LEDC_TIMER_0, // Use timer 0
.duty = 128, // 50% duty cycle (128/255)
.hpoint = 0 // Start at high point 0
ledc_channel_config(&ledc_channel);
Serial.println("38kHz PWM started.");
// Continuously output the carrier wave
5-IR-send-ESP32.zip (Size: 904 bytes / Downloads: 584)
5-IR-send-ESP32.ino.merged.zip (Size: 187.02 KB / Downloads: 551)
