[arduino code examples for AIO Hybrid]-06 How to use SD Card
* SD Card File Operations
* Hardware Connections:
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  } else {
  file.close();
  if (!file) {
    return;
  } else {
  file.close();
void deleteFile(fs::FS &fs, const char * path) {
  if (fs.remove(path)) {
  } else {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  } else {
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
  } else {
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 287)
.zip   6-SD.ino.merged.zip (Size: 221.05 KB / Downloads: 318)
