Threads: 4
Why does it have so few dry-contact inputs? only 12 ...
old ESP32 AIO has 56
Is there any option to increase this and have external inputs available in one KCS v3 configuration (to use any input from outsite AIO Hybrid in AIO Hybrid IFTTT)?
Threads: 4
Or do You have any video or description how to set:
- RS485 between controllers,
- WiFi AP (to communicate even in lack of local network),
and how to set it in KCS IFTTT to use controller1_input to trigger controller2_output etc?
Threads: 1,333
1. we will make video tour to explain AIO Hybrid board.
2. use IFTTT, send customize protocol to other controller's by HTTP or TCP command.
Threads: 4
But will the http or tcp command work if the controllers are connected to the internet router (via WiFi/ethernet cable) in case of a router failure?
Threads: 1,333
they are work in local network without internet.
