F24 work with HAv2 without tuya app ESPHome yaml
  friendly_name: HAv2
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
  baud_rate: 0
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.1
uart:
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: false
kc868_ha:
  # The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
  # bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
  # Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
  - platform: kc868_ha
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  # The switch is used to control the D1~D6 level output on the KC868 HA board
  # Other parameters refer to: https://esphome.io/components/switch/index.html
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
web_server:
  port: 80
esphome yaml file download:
.txt   HAv2-F24-yaml.txt (Size: 3.04 KB / Downloads: 65)
