Analog Input NTC
I’m trying to connect a 10 kΩ NTC temperature sensor to my KC868-A16 board.
Unfortunately, I don’t get any readings at all.
Which GPIO pins are actually used for the analog inputs?
I used the example code from this forum, but I don’t get any plausible values on any pin.
I also tested by connecting each pin to GND to rule out a sensor issue, but the readings still don’t change.
I’m stuck now — what is the correct code to read the analog inputs properly?
Thanks in advance for your help!
KC868-A16 analog input use by 0-5v signal. so you can chose some 0-5v temperature sensor. such as this one: https://shop.kincony.com/products/temper...ity-sensor
Its not possible to use another sensor because its is already build system. So how can I read out the analog inputs? There are a bunch of different information with Pins to use? Do I need a voltage divider?
maybe you can find a NTC covert to 0-5v small module.
