Threads: 1
I’ve recently got this board and intend to use it for operating several valves.
Could someone confirm if it’s possible to run 24 VAC through the output channels?
Thanks in advance!
Threads: 1,282
KC868-A16 is mosfet output, it can directly work with DC 24V load, NOT AC 24v load. if your valve is AC24V, need add extend relay module -- KC868-E16v2
Threads: 0
It's essential to note that the KC868-A16 board is designed for DC 24V load, not AC. Have you considered alternatives for running your valves with 24VAC?
Threads: 1,282
if you want to use 24VAC valve, please chose 16 channel relay board. Not chose mosfet version.
