F4 ESPHome yaml for home assistant with tuya
  friendly_name: f4
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.3.0
  # hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
pcf8574:
  - id: 'pcf8574_hub_in_1'  # for DI1-DI4 Relay1-Relay4
    i2c_id: bus_a
    address: 0x24
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: nnr2qbxrwuleqqgc
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_in_1
      number: 4
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f4_output01"
      number: 5
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "f4_output02"
      number: 6
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "f4_output03"
      number: 7
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "f4_output04"
      mode: INPUT
    dp_id: 111
    bind_binary_sensor_id: f4_input01
    internal: true
      number: 1
      mode: INPUT
    dp_id: 112
    bind_binary_sensor_id: f4_input02
    internal: true
      number: 2
      mode: INPUT
    dp_id: 113
    bind_binary_sensor_id: f4_input03
    internal: true
      number: 3
      mode: INPUT
    dp_id: 114
    bind_binary_sensor_id: f4_input04
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 14
      inverted:  false
      number: 40
      inverted:  false
      inverted:  false
  - platform: adc
    pin: 5
    name: "f4 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f4 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f4 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f4 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony f4");
esphome yaml file:
.txt   F4-HA-tuya.txt (Size: 6.04 KB / Downloads: 200)
