WHATS FIRMWARE
Hello, it's been 4 days since this motherboard arrived and I'm trying to get this KC868 E16T-V1.2 working because the access point option doesn't appear. I tried connecting it via cable to see if I could find it on the network, but without success. I can only see it through the USB cable, so I'd like to know which firmware I can install and a step-by-step guide to get it working using Tuya.
do you use for home assistant?
I need working tuya
you can download this fimrware to Tuya:
https://www.kincony.com/forum/showthread.php?tid=2421
I managed to get the board working, but there's a problem: I can't change how some buttons function. For example, I need some buttons to only be activated when a relay is closing the circuit. How can I change this using the Tuya system?
you can config esphome yaml file, let digital input toggle relay output.
Hello, I need to set ports 1, 2, 3, 4, and 5 to "close" mode when the external device is turned on, and "open" when the device is turned off. I modified the code but I can't install it. I need to get this working so I can buy more.
I am sending the code below.
.txt   new cod 2.txt (Size: 12.61 KB / Downloads: 224)
change the tuya component to new version. change code as this:
external_components:
  - source:
      type: git
      ref: v1.3.1
you are using old v1.1.0
