Analog Inputs via MQTT HA Auto Discover
When using HA Auto Discover with KCS 3, should the analog inputs be detected and shown in Home Assistant?  I'm only getting the digital inputs.  Or do I need to use ESP Home?
what KCS v3 frimware you have downloaded? use for F16? analog input should found in Home Assistant.
if you want use ESPHome, also is ok for analog input ports.
