a16v3 - reed switch and motion sensor connection
I have problem to connect reed switch (for doors and windows) and (motion sensor).
I trying to use a16v3 as alarm (connection with HA and Alarmo)
1. I have problem because when I connect reed switch Satel K-2 2E the Input alway ON. and when I bring the magnet closer to the read switch nothing changed.
Two cables: 1 GND , 2 DI1
A16v3 is connected to ESP Home.
.txt   sphomel.txt (Size: 8.9 KB / Downloads: 286)
Sensors configuration:
  device_class: door
    pcf8574: pcf8554_hub_in_1
    modę: INPUT
  filters:
    - deleyted_on: 100ms
    - deleyted_off: 3s
2. I have second problem with Motion Sensor Satel Graphite. Connect to 12V, GND and Input and is Enabling only when push "tamper switch" and its enabling always. but should enable only when motion sensor it detects movement.
Connection
12v in sensor to 12v in a16v3
COM in sensor to GDN
NC in sensor to Input PIR DI13
Configuration
- platform: glio
  device_class: motion
    pcf8574: pcf8554_hub_in_2
    number: 4
    modę: INPUT
    filters:
      - deleyted_off: 3s
In LOGS:
D binary_sensor:041 PIR DI13 New state is ON, pull down form tamper switch and state is OFF.
when A16v3 digtal input short with GND = sensor ON. so make sure your device logical by this way. Maybe you can change your COM, NO, NC port signal for A16v3.
(11-20-2025, 11:16 PM)admin Wrote: when A16v3 digtal input short with GND = sensor ON. so make sure your device logical by this way. Maybe you can change your COM, NO, NC port signal for A16v3.
Hello, Thanks for replay
I think there are visible in a16v3 as switch. But via ESP Home there are configured as binary_sensor. As on the photo is door sensor and motion sensor should work ?
1. But state should change when I bring the magnet closer to the read switch. But nothing changed. Wrong configuration? Wrong reed switch?
when A16v3 digtal input short with GND = sensor ON. so make sure your device logical by this way. What I can change?
2. Same with motion sensor. State only change when I push "tamper switch". There is no state change when sensor see the motion.
Maybe you can change your COM, NO, NC port signal for A16v3. How to do that?
i suggest you use multi meter to test, when sensor trigger the output signal.
(11-22-2025, 12:29 AM)admin Wrote: i suggest you use multi meter to test, when sensor trigger the output signal.
ok. it's started working. Thanks Smile
Can you please tell me Is there an option to  connect SIM7600e module to a16v3 ?  https://shop.kincony.com/products/kincon...QHlgF-KsXN
It's working now. Smile thanks
If there is any chance to connect some GSM module like https://www.kincony.com/sim7600e-4g-module.html to a16v4 board?
sure, you can use A16v3 free GPIOs on PCB, connect with two free gpio work as RXD and TXD pin for SIM7600 4G module.
Do you have some yaml file for ESP Home with sim7600e integration ?
see here: https://www.kincony.com/forum/forumdisplay.php?fid=54
use SMS and voice call by SIM7600 for ESPHome.
