KC-868-A1 linked Home Assistant
Try to linked up with my home assistant. I am getting these error from ESPHOME see photo:
why?
I get responded from kincony that - esphome new version have new syntax.
So what do i do to solve these problems?  What do I have to do, advise please.
[Image: A2c3321349c4c49909eccbc72379d5ea2d.jpg]
.txt   KC868-ai for Home Assistant.txt (Size: 7.9 KB / Downloads: 114)
please use this newest yaml will be work well.
  friendly_name: kc868-ai
esp32:
  board: esp32dev
  framework:
    type: esp-idf
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
pcf8574:
    address: 0x24
    address: 0x25
  - id: 'pcf8574_hub_in_3'  # for input channel 17-24
    address: 0x21
  - id: 'pcf8574_hub_in_4'  # for input channel 25-32
    address: 0x22
  - id: 'pcf8574_hub_in_5'  # for input channel 33-40
    address: 0x26
  - id: 'pcf8574_hub_in_6'  # for input channel 41-48
    address: 0x23
# Individual outputs
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_4
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_5
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_6
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
yaml file download:
.txt   KC868-AI_ESPhome.txt (Size: 7.83 KB / Downloads: 102)
Thanks for that! i can see small amended in script :esp32 area.
installed to kc-868-a1 without problems, now add card in my home assistant.... asking me for api: - encryption key?
where i get this from? i found api: at the bottom of script but nothing there.
delete your KC868-AI device in ESPHome. add again use by another new device name, i think will be ok.
