Threads: 3
Hi,
in the modbus specifiaction from N30 it is mentioned that Energy Sensor from BL0910 has a resolution of 1kWh only.
Is there any way to get a more accurat reading? For power circuits with low consumption it is misleading to see 0kWh consumption on end of day.
Does the BL0910 has a possibility to report for example 0,1kWh as resolution for Energy Consumption?
Thank you.
br
Threads: 1,403
BL0910 only can use by 1KWH, can't use 0.1KWH.
about consumption data bug, we will update firmware soon.
Threads: 1
02-16-2026, 12:16 PM
(This post was last modified: 02-16-2026, 12:17 PM by Painy.)
Can't you fix this with software? For example, in ESHPhome config integration sensor rather than using BL0910 hardware for kWh resolution?
Threads: 1,403
after China New Year holidays , we will check it.
Threads: 1
02-17-2026, 10:30 AM
Thank you.
Have a great newyear !
Threads: 1,403
The calculation of electrical energy is achieved by integrating the BL0910 chip to obtain a count value, which is 1KWH units. There is no way to change it.
Threads: 4
Completly useless this 1kWh resolution for home usage, will take forever to get a reading. More suitable if you have +100A loads.
Waisted a lot of money for someting what looked nice on paper, next time add the specs and resolutions so we know before we buy.
