02-03-2026, 12:17 AM
friendly_name: dm4
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
ota:
platform: esphome
web_server:
port: 80
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
text_sensor:
- platform: ethernet_info
ip_address:
name: ESP IP Address
address_0:
name: ESP IP Address 0
address_1:
name: ESP IP Address 1
address_2:
name: ESP IP Address 2
address_3:
name: ESP IP Address 3
address_4:
name: ESP IP Address 4
dns_address:
name: ESP DNS Address
mac_address:
name: ESP MAC Address
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 38
rx_pin: 39
- platform: uart
uart_id: uart_1
pcf8574:
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: false
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
##pull-up resistance on PCB
number: 48
number: 47
number: 40
number: 17
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 21
inverted: false
inverted: false
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
mcp4728:
- id: dac_output
output:
- platform: mcp4728
mcp4728_id: dac_output
channel: A
vref: internal
- platform: mcp4728
channel: B
vref: internal
- platform: mcp4728
channel: C
vref: internal
- platform: mcp4728
channel: D
vref: internal
light:
- platform: monochromatic
output: ac_dimmer_1
gamma_correct: 1.0
output: ac_dimmer_2
gamma_correct: 1.0
output: ac_dimmer_3
gamma_correct: 1.0
output: ac_dimmer_4
gamma_correct: 1.0esphome yaml file download:
DM4-HA-without Tuya.txt (Size: 4.4 KB / Downloads: 71)
