communication between 2 boards
I have kc868-A16 and kc868-AP board, both connected with ethernet cable to the router. Both has their own IP-address.
Is it possible without using homeassistant to have an input on one board to control an output on the other board ?
With a long push on a button on input 1 from board KC868-A16, all outputs on KC868-a16 and KC868-AP has to go OFF.
Is this possible ? I cannot find an example in the description how to do this.
sure, they can work without home assistant. just download KCS firmware, use by IFTTT create AUTOMATION. send customize protocol to different board. Here is KCS v2 firmware online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
In the link you mentioned, I cannot find the information. Is it possible to give an example how to do this ?
I have seen on the forum that others also asked this but they also didn't receive an satified answer with an example.
So please provide us with an example
this is sample video tour: https://youtu.be/UumHtpZiURY
Yes, it’s possible with KCS firmware using “Send Custom Protocol” between the two boards. You’ll need to set the KC868-A16 button as a trigger and configure an automation that sends an HTTP or TCP command to the IP of the KC868-AP to turn outputs OFF. Could you share which protocol you’re using so we can give a more exact command example?
