Recommendation for N60 wiring?
How are people wiring into the terminal blocks on the N60? Should I add ferrules to the 3.5mm female jack tails or is there a better way?
you can cut the jack, connect terminal by screw directly.
The N60 doesn't have screws though, it has spring/wire connectors that are difficult to insert a stranded wire into.
Add solder to the wire
