[arduino code examples for B32M]-02 Read digital input ports state
* Description:
* This Arduino program reads the state of two 16-channel PCF8575 I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22 for inputs 1-16, 0x25 for inputs 17-24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C addresses
PCF8575 pcf8575_IN1(0x22); // The I2C address of the first PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(0x25); // The I2C address of the second PCF8575 (inputs 17-24)
PCF8575 pcf8575_IN3(0x26); // The I2C address of the second PCF8575 (inputs 25-32)
    // Initialize both PCF8575 modules
    pcf8575_IN1.begin();
    pcf8575_IN2.begin();
    pcf8575_IN3.begin();
    Serial.println("KinCony B32 32 channel input state 0:ON  1:OFF");
if (pcf8575_IN1.read(8)==0) {Serial.print("DI1 state="); Serial.println("on");}
if (pcf8575_IN1.read(9)==0) {Serial.print("DI2 state="); Serial.println("on");}
if (pcf8575_IN1.read(10)==0) {Serial.print("DI3 state="); Serial.println("on");}
if (pcf8575_IN1.read(11)==0) {Serial.print("DI4 state="); Serial.println("on");}
if (pcf8575_IN1.read(12)==0) {Serial.print("DI5 state="); Serial.println("on");}
if (pcf8575_IN1.read(13)==0) {Serial.print("DI6 state="); Serial.println("on");}
if (pcf8575_IN1.read(14)==0) {Serial.print("DI7 state="); Serial.println("on");}
if (pcf8575_IN1.read(15)==0) {Serial.print("DI8 state="); Serial.println("on");}
if (pcf8575_IN1.read(0)==0) {Serial.print("DI9 state="); Serial.println("on");}
if (pcf8575_IN1.read(1)==0) {Serial.print("DI10 state="); Serial.println("on");}
if (pcf8575_IN1.read(2)==0) {Serial.print("DI11 state="); Serial.println("on");}
if (pcf8575_IN1.read(3)==0) {Serial.print("DI12 state="); Serial.println("on");}
if (pcf8575_IN1.read(4)==0) {Serial.print("DI13 state="); Serial.println("on");}
if (pcf8575_IN1.read(5)==0) {Serial.print("DI14 state="); Serial.println("on");}
if (pcf8575_IN1.read(6)==0) {Serial.print("DI15 state="); Serial.println("on");}
if (pcf8575_IN1.read(7)==0) {Serial.print("DI16 state="); Serial.println("on");}
if (pcf8575_IN2.read(0)==0) {Serial.print("DI17 state="); Serial.println("on");}
if (pcf8575_IN2.read(1)==0) {Serial.print("DI18 state="); Serial.println("on");}
if (pcf8575_IN2.read(2)==0) {Serial.print("DI19 state="); Serial.println("on");}
if (pcf8575_IN2.read(3)==0) {Serial.print("DI20 state="); Serial.println("on");}
if (pcf8575_IN2.read(4)==0) {Serial.print("DI21 state="); Serial.println("on");}
if (pcf8575_IN2.read(5)==0) {Serial.print("DI22 state="); Serial.println("on");}
if (pcf8575_IN2.read(6)==0) {Serial.print("DI23 state="); Serial.println("on");}
if (pcf8575_IN2.read(7)==0) {Serial.print("DI24 state="); Serial.println("on");}
if (pcf8575_IN3.read(0)==0) {Serial.print("DI25 state="); Serial.println("on");}
if (pcf8575_IN3.read(1)==0) {Serial.print("DI26 state="); Serial.println("on");}
if (pcf8575_IN3.read(2)==0) {Serial.print("DI27 state="); Serial.println("on");}
if (pcf8575_IN3.read(3)==0) {Serial.print("DI28 state="); Serial.println("on");}
if (pcf8575_IN3.read(4)==0) {Serial.print("DI29 state="); Serial.println("on");}
if (pcf8575_IN3.read(5)==0) {Serial.print("DI30 state="); Serial.println("on");}
if (pcf8575_IN3.read(6)==0) {Serial.print("DI31 state="); Serial.println("on");}
if (pcf8575_IN3.read(7)==0) {Serial.print("DI32 state="); Serial.println("on");}
    delay(1000); // Delay 500ms
.zip   2-digital-input.zip (Size: 942 bytes / Downloads: 13)
.zip   2-digital-input.ino.merged.zip (Size: 198.36 KB / Downloads: 12)
