Adding a debounce capability to inputs
At the moment the KC868 inputs are instantaneous which is a problem for signals that glitch occasionally from things like noise coupled onto the input lines.  Would it be possible to add a debounce capability where you can specify that an input has to be asserted for x seconds, x user-settable, before it gets reported as an asserted input?  What I'm thinking of is adding a per-input capability where you can specify that it needs to be asserted for (say) 5 seconds before it's treated as valid.  The overall range would be maybe 0-60s, 0s = instant response, > 0s = input must be asserted for that long before it's reported as asserted.
ok, will save your suggestion. if config by ESPHome, it support debounce.
Thanks!  I'm using the KCS firmware because it's much nicer/easier to work with than ESPHome.
ok
here is new KCS v3 firmware with debounce option. You can try.
The System page has added an input debounce time option, with a default of 5 ms.
.zip   KCS_A16V3_V3.24.3_beta_20260402-152259.zip (Size: 1.15 MB / Downloads: 260)
Thanks! For anyone else using this, it's marked as "input delay time".
yes, newest KCS v3 firmware support the "debounce" function.
