03-17-2026, 12:50 AM
friendly_name: dm32
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
uart:
- id: uart_1 # RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 39
rx_pin: 38
- id: dac_uart
rx_pin: 4
tx_pin: 6
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
debug:
modbus:
uart_id: dac_uart
modbus_controller:
- address: 1
update_interval: 5s
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
text_sensor:
- platform: ethernet_info
ip_address:
name: ESP IP Address
address_0:
name: ESP IP Address 0
address_1:
name: ESP IP Address 1
address_2:
name: ESP IP Address 2
address_3:
name: ESP IP Address 3
address_4:
name: ESP IP Address 4
dns_address:
name: ESP DNS Address
mac_address:
name: ESP MAC Address
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
output:
# CH1 (0x0FA0 / 4000)
- platform: modbus_controller
address: 0x0FA0
value_type: U_WORD
write_lambda: |-
// state = 0.0 ~ 1.0 → 0 ~ 4095
uint16_t reg = (uint16_t) round(x * 4095.0);
return reg;
# CH2 (0x0FA1 / 4001)
address: 0x0FA1
value_type: U_WORD
write_lambda: |-
return reg;
# CH3
address: 0x0FA2
value_type: U_WORD
write_lambda: |-
return reg;
# CH4
address: 0x0FA3
value_type: U_WORD
write_lambda: |-
return reg;
# CH5
address: 0x0FA4
value_type: U_WORD
write_lambda: |-
return reg;
# CH6
address: 0x0FA5
value_type: U_WORD
write_lambda: |-
return reg;
# CH7
address: 0x0FA6
value_type: U_WORD
write_lambda: |-
return reg;
# CH8
address: 0x0FA7
value_type: U_WORD
write_lambda: |-
return reg;
# CH9
address: 0x0FA8
value_type: U_WORD
write_lambda: |-
return reg;
# CH10
address: 0x0FA9
value_type: U_WORD
write_lambda: |-
return reg;
# CH11
address: 0x0FAA
value_type: U_WORD
write_lambda: |-
return reg;
# CH12
address: 0x0FAB
value_type: U_WORD
write_lambda: |-
return reg;
# CH13
address: 0x0FAC
value_type: U_WORD
write_lambda: |-
return reg;
# CH14
address: 0x0FAD
value_type: U_WORD
write_lambda: |-
return reg;
# CH15
address: 0x0FAE
value_type: U_WORD
write_lambda: |-
return reg;
# CH16
address: 0x0FAF
value_type: U_WORD
write_lambda: |-
return reg;
# CH17 (0x0FB0 / 4016)
address: 0x0FB0
value_type: U_WORD
write_lambda: |-
return reg;
# CH18
address: 0x0FB1
value_type: U_WORD
write_lambda: |-
return reg;
# CH19
address: 0x0FB2
value_type: U_WORD
write_lambda: |-
return reg;
# CH20
address: 0x0FB3
value_type: U_WORD
write_lambda: |-
return reg;
# CH21
address: 0x0FB4
value_type: U_WORD
write_lambda: |-
return reg;
# CH22
address: 0x0FB5
value_type: U_WORD
write_lambda: |-
return reg;
# CH23
address: 0x0FB6
value_type: U_WORD
write_lambda: |-
return reg;
# CH24
address: 0x0FB7
value_type: U_WORD
write_lambda: |-
return reg;
# CH25
address: 0x0FB8
value_type: U_WORD
write_lambda: |-
return reg;
# CH26
address: 0x0FB9
value_type: U_WORD
write_lambda: |-
return reg;
# CH27
address: 0x0FBA
value_type: U_WORD
write_lambda: |-
return reg;
# CH28
address: 0x0FBB
value_type: U_WORD
write_lambda: |-
return reg;
# CH29
address: 0x0FBC
value_type: U_WORD
write_lambda: |-
return reg;
# CH30
address: 0x0FBD
value_type: U_WORD
write_lambda: |-
return reg;
# CH31
address: 0x0FBE
value_type: U_WORD
write_lambda: |-
return reg;
# CH32 (0x0FBF / 4031)
address: 0x0FBF
value_type: U_WORD
write_lambda: |-
return reg;
light:
- platform: monochromatic
output: dac_ch1_out
default_transition_length: 0s
output: dac_ch2_out
output: dac_ch3_out
output: dac_ch4_out
output: dac_ch5_out
output: dac_ch6_out
output: dac_ch7_out
output: dac_ch8_out
output: dac_ch9_out
output: dac_ch10_out
output: dac_ch11_out
output: dac_ch12_out
output: dac_ch13_out
output: dac_ch14_out
output: dac_ch15_out
output: dac_ch16_out
output: dac_ch17_out
output: dac_ch18_out
output: dac_ch19_out
output: dac_ch20_out
output: dac_ch21_out
output: dac_ch22_out
output: dac_ch23_out
output: dac_ch24_out
output: dac_ch25_out
output: dac_ch26_out
output: dac_ch27_out
output: dac_ch28_out
output: dac_ch29_out
output: dac_ch30_out
output: dac_ch31_out
output: dac_ch32_out
pcf8574:
- id: pcf8574_hub_1 # for input channel 1-16
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: pcf8574_hub_2 # for input channel 17-32
i2c_id: bus_a
address: 0x24
pcf8575: true
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_1
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
pcf8574: pcf8574_hub_2
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 8
mode: INPUT
number: 9
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
## pull-up resistance on PCB
number: 47
number: 48
number: 7
number: 40
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 21
inverted: false
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
esphome_dm32.txt (Size: 17.6 KB / Downloads: 26)
