03-23-2026, 01:54 AM
note: ARM CPU firmware version should >= V20_260305SP
ARM CPU firmware download: https://www.kincony.com/forum/showthread.php?tid=9107
yaml download:
n10_esphome.txt (Size: 12.27 KB / Downloads: 31)
friendly_name: n10
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# baud_rate: 0
ota:
platform: esphome
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
uart:
rx_pin: 9
tx_pin: 10
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
web_server:
port: 80
text_sensor:
- platform: ethernet_info
ip_address:
name: ESP IP Address
dns_address:
name: ESP DNS Address
mac_address:
name: ESP MAC Address
font:
- file: "gfonts://Roboto"
sda: 18
scl: 17
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
modbus:
uart_id: uart_modbus
modbus_controller:
- id: energy_meter
modbus_id: mb1
address: 1
update_interval: 5s
command_throttle: 200ms
# Protocol notes for this PR:
# - current: U_DWORD_R, scaled by 0.001 A
# - power: S_DWORD_R, scaled by 0.1 W
# - energy: FP32_R, unit kWh
# - voltage/frequency remain U_WORD * 0.01
# - temperature remains FP32_R
- platform: modbus_controller
modbus_controller_id: energy_meter
address: 100
register_type: holding
unit_of_measurement: A
device_class: current
state_class: measurement
accuracy_decimals: 3
value_type: U_DWORD_R
filters:
- multiply: 0.001
address: 102
filters:
- multiply: 0.001
address: 104
filters:
- multiply: 0.001
address: 106
filters:
- multiply: 0.001
address: 108
filters:
- multiply: 0.001
address: 110
filters:
- multiply: 0.001
address: 112
filters:
- multiply: 0.001
address: 114
filters:
- multiply: 0.001
address: 116
filters:
- multiply: 0.001
address: 118
filters:
- multiply: 0.001
address: 120
unit_of_measurement: W
device_class: power
accuracy_decimals: 1
value_type: S_DWORD_R
filters:
- multiply: 0.1
address: 122
device_class: power
filters:
- multiply: 0.1
address: 124
device_class: power
filters:
- multiply: 0.1
address: 126
device_class: power
filters:
- multiply: 0.1
address: 128
device_class: power
filters:
- multiply: 0.1
address: 130
device_class: power
filters:
- multiply: 0.1
address: 132
device_class: power
filters:
- multiply: 0.1
address: 134
device_class: power
filters:
- multiply: 0.1
address: 136
device_class: power
filters:
- multiply: 0.1
address: 138
device_class: power
filters:
- multiply: 0.1
address: 140
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
value_type: FP32_R
address: 142
value_type: FP32_R
address: 144
value_type: FP32_R
address: 146
value_type: FP32_R
address: 148
value_type: FP32_R
address: 150
value_type: FP32_R
address: 152
value_type: FP32_R
address: 154
value_type: FP32_R
address: 156
value_type: FP32_R
address: 158
value_type: FP32_R
address: 160
value_type: FP32_R
address: 162
unit_of_measurement: V
device_class: voltage
accuracy_decimals: 2
value_type: U_WORD
filters:
- multiply: 0.01
address: 163
unit_of_measurement: Hz
device_class: frequency
value_type: U_WORD
filters:
- multiply: 0.01
address: 164
unit_of_measurement: °C
device_class: temperature
value_type: FP32_R
address: 166
value_type: FP32_R
