"KCS" v3.25.0 firmware BIN file download
new version improvement:
1. Daylight saving time adaptation (add DST configuration to firmware system + IFTTT automatic adjustment to new time)
2. Multi-channel configuration support for the Wiegand protocol
3. Display cumulative online duration on the web page (web + MQTT + HA)
4. Support for third-party sensor integration using the standard Modbus protocol
5. add send IR signal to ALL GPIO channels
6. add mqtt "force update" option for home assistant
.zip   KCS_A2V3_V3.25.0.zip (Size: 1.18 MB / Downloads: 237)
.zip   KCS_A6V3_V3.25.0.zip (Size: 1.15 MB / Downloads: 200)
.zip   KCS_A8V3_V3.25.0.zip (Size: 1.21 MB / Downloads: 251)
.zip   KCS_A16V3_V3.25.0.zip (Size: 1.22 MB / Downloads: 253)
.zip   KCS_A32PRO_V3.25.0.zip (Size: 1.19 MB / Downloads: 173)
.zip   KCS_AG8_V3.25.0.zip (Size: 1.17 MB / Downloads: 156)
.zip   KCS_AGV3_V3.25.0.zip (Size: 1.12 MB / Downloads: 198)
.zip   KCS_AIO_HYBRID_V3.25.0.zip (Size: 1.4 MB / Downloads: 203)
.zip   KCS_ALR_V3.25.0.zip (Size: 1.16 MB / Downloads: 183)
.zip   KCS_B4_V3.25.0.zip (Size: 1.21 MB / Downloads: 163)
.zip   KCS_B4M_V3.25.0.zip (Size: 1.21 MB / Downloads: 175)
.zip   KCS_B8_V3.25.0.zip (Size: 1.21 MB / Downloads: 160)
.zip   KCS_B8M_V3.25.0.zip (Size: 1.21 MB / Downloads: 186)
.zip   KCS_B16_V3.25.0.zip (Size: 1.21 MB / Downloads: 179)
.zip   KCS_B16M_V3.25.0.zip (Size: 1.21 MB / Downloads: 228)
.zip   KCS_B24_V3.25.0.zip (Size: 1.21 MB / Downloads: 188)
.zip   KCS_B24M_V3.25.0.zip (Size: 1.21 MB / Downloads: 165)
.zip   KCS_B32M_V3.25.0.zip (Size: 1.21 MB / Downloads: 163)
.zip   KCS_DM4_V3.25.0.zip (Size: 1.22 MB / Downloads: 166)
.zip   KCS_DM8_V3.25.0.zip (Size: 1.22 MB / Downloads: 183)
.zip   KCS_DM16_V3.25.0.zip (Size: 1.19 MB / Downloads: 206)
.zip   KCS_DM32_V3.25.0.zip (Size: 1.22 MB / Downloads: 167)
.zip   KCS_F4_V3.25.0.zip (Size: 1.21 MB / Downloads: 158)
.zip   KCS_F8_V3.25.0.zip (Size: 1.21 MB / Downloads: 204)
.zip   KCS_F16_V3.25.0.zip (Size: 1.22 MB / Downloads: 193)
.zip   KCS_F24_V3.25.0.zip (Size: 1.22 MB / Downloads: 166)
.zip   KCS_F32_V3.25.0.zip (Size: 1.22 MB / Downloads: 161)
.zip   KCS_G1_V3.25.0.zip (Size: 1.17 MB / Downloads: 170)
.zip   KCS_KC_TA_V3.25.0.zip (Size: 1.17 MB / Downloads: 185)
.zip   KCS_N10_V3.25.0.zip (Size: 1.08 MB / Downloads: 160)
.zip   KCS_N20_V3.25.0.zip (Size: 1.08 MB / Downloads: 176)
.zip   KCS_N30_V3.25.0.zip (Size: 1.08 MB / Downloads: 183)
.zip   KCS_N60_V3.25.0.zip (Size: 1.09 MB / Downloads: 172)
.zip   KCS_T16M_V3.25.0.zip (Size: 1.16 MB / Downloads: 164)
.zip   KCS_T32M_V3.25.0.zip (Size: 1.18 MB / Downloads: 179)
.zip   KCS_T64M_V3.25.0.zip (Size: 1.18 MB / Downloads: 162)
.zip   KCS_T128M_V3.25.0.zip (Size: 1.18 MB / Downloads: 185)
.zip   KCS_TR_V3.25.0.zip (Size: 1.14 MB / Downloads: 182)
.zip   KCS_Z1_V3.25.0.zip (Size: 1.31 MB / Downloads: 169)
How I can upload this to remote device?
only by USB-C cable.
I have the A8V3 and I can't get this to flash via USB.
https://www.kincony.com/kcs-firmware-esp32-board.html
I followed those instructions but when I hit start, the board cycles the relays a number of times then returns "2-sync fail Tips: Please refer to the chip datasheet and confirm that the strapping pins's status is correct"
I've tried the baud 921600 as well as 115200 and 1152000, same results.
A8v3 use by ESP32S3, so you should download KCS v3 firmware,
this is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
you are seeing KCS v2 online guide, that not for A8v3.
Smile
Hi, with the T64M module, there's no option to select momentary mode on the output page. There's only Hold or Delay. Can you check?
Thanks.
which fimrware version you are using? take a photo of your screen that no option.
(06-11-2026, 07:46 PM)admin Wrote: which fimrware version you are using? take a photo of your screen that no option.
Resolved.
I found the settings in the system page ( " keep output after restart"  set to off ")
Thank You
ok
